I own an NUC9i7QNX and used it for software development with Intel SGX.
To run the SGX application, the current environment(mostly firmware) must be passed with a Remote Attestation report from Intel IAS flow. Below is the report I got from the IAS:
isvEnclaveQuoteStatus = CONFIGURATION_AND_SW_HARDENING_NEEDED
advisoryURL = https://security-center.intel.com
advisoryIDs = "INTEL-SA-00161", "INTEL-SA-00219", "INTEL-SA-00289", "INTEL-SA-00334", "INTEL-SA-00615"
There 2 issues:
1. As is informed in https://www.intel.com/content/www/us/en/security-center/advisory/intel-sa-00115.html, INTEL-SA-00161 has already been fixed in 2018 and the NUC9 line should not be affected to it.
2. As is informed in https://www.intel.com/content/www/us/en/security-center/advisory/intel-sa-00219.html, INTEL-SA-00219 has already been fixed in 2019 with the internal graphic device disabled. I have iGPU disabled and installed an AMD GPU but still got the system affected with INTEL-SA-00219. Below are returned from `lspci`:
[krhougs@nuc3 ~]$ lspci
00:00.0 Host bridge: Intel Corporation 8th Gen Core Processor Host Bridge/DRAM Registers (rev 07)
00:01.0 PCI bridge: Intel Corporation 6th-10th Gen Core Processor PCIe Controller (x16) (rev 07)
00:08.0 System peripheral: Intel Corporation Xeon E3-1200 v5/v6 / E3-1500 v5 / 6th/7th/8th Gen Core Processor Gaussian Mixture Model
00:12.0 Signal processing controller: Intel Corporation Cannon Lake PCH Thermal Controller (rev 10)
00:14.0 USB controller: Intel Corporation Cannon Lake PCH USB 3.1 xHCI Host Controller (rev 10)
00:14.2 RAM memory: Intel Corporation Cannon Lake PCH Shared SRAM (rev 10)
00:15.0 Serial bus controller: Intel Corporation Cannon Lake PCH Serial IO I2C Controller #0 (rev 10)
00:15.1 Serial bus controller: Intel Corporation Cannon Lake PCH Serial IO I2C Controller #1 (rev 10)
00:16.0 Communication controller: Intel Corporation Cannon Lake PCH HECI Controller (rev 10)
00:17.0 SATA controller: Intel Corporation Cannon Lake Mobile PCH SATA AHCI Controller (rev 10)
00:1c.0 PCI bridge: Intel Corporation Cannon Lake PCH PCI Express Root Port #1 (rev f0)
00:1c.4 PCI bridge: Intel Corporation Cannon Lake PCH PCI Express Root Port #5 (rev f0)
00:1d.0 PCI bridge: Intel Corporation Cannon Lake PCH PCI Express Root Port #14 (rev f0)
00:1e.0 Communication controller: Intel Corporation Cannon Lake PCH Serial IO UART Host Controller (rev 10)
00:1f.0 ISA bridge: Intel Corporation Cannon Lake LPC Controller (rev 10)
00:1f.3 Audio device: Intel Corporation Cannon Lake PCH cAVS (rev 10)
00:1f.4 SMBus: Intel Corporation Cannon Lake PCH SMBus Controller (rev 10)
00:1f.5 Serial bus controller: Intel Corporation Cannon Lake PCH SPI Controller (rev 10)
00:1f.6 Ethernet controller: Intel Corporation Ethernet Connection (7) I219-LM (rev 10)
01:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Oland XT [Radeon HD 8670 / R5 340X OEM / R7 250/350/350X OEM] (rev 83)
01:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Oland/Hainan/Cape Verde/Pitcairn HDMI Audio [Radeon HD 7000 Series]
02:00.0 Network controller: Intel Corporation Wi-Fi 6 AX200 (rev 1a)
03:00.0 PCI bridge: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge 4C 2018] (rev 06)
04:00.0 PCI bridge: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge 4C 2018] (rev 06)
04:01.0 PCI bridge: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge 4C 2018] (rev 06)
04:02.0 PCI bridge: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge 4C 2018] (rev 06)
04:04.0 PCI bridge: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge 4C 2018] (rev 06)
05:00.0 System peripheral: Intel Corporation JHL7540 Thunderbolt 3 NHI [Titan Ridge 4C 2018] (rev 06)
39:00.0 USB controller: Intel Corporation JHL7540 Thunderbolt 3 USB Controller [Titan Ridge 4C 2018] (rev 06)
6e:00.0 Ethernet controller: Intel Corporation I210 Gigabit Network Connection (rev 03)
I suspect that there should be some problem with the firmware or microcode.
The firmware version I tried is QX0071 and QX0070, they both have the same issue.
OS version:
Linux nuc3 6.1.6-arch1-3 #1 SMP PREEMPT_DYNAMIC Mon, 16 Jan 2023 12:51:23 +0000 x86_64 GNU/Linux
Some useful info to debug:
[krhougs@nuc3 ~]$ sudo dmesg | grep microcode
[ 0.779079] microcode: sig=0x906ea, pf=0x20, revision=0xf0
[ 0.779240] microcode: Microcode Update Driver: v2.2.
[krhougs@nuc3 ~]$ grep 'stepping\|model\|microcode' /proc/cpuinfo
model : 158
model name : Intel(R) Core(TM) i7-9750H CPU @ 2.60GHz
stepping : 10
microcode : 0xf0
model : 158
stepping : 10
microcode : 0xf0
model : 158
stepping : 10
microcode : 0xf0
model : 158
stepping : 10
microcode : 0xf0
model : 158
stepping : 10
microcode : 0xf0
model : 158
stepping : 10
microcode : 0xf0
Hello orancho,
I will take this information and investigate about this. As soon as I have an update, I will let you know.
Steven G.
Hello orancho,
Please be aware that this issue should be fixed now. Are you getting this issue when using one of the supported operating systems (https://www.intel.com/content/www/us/en/support/articles/000005628/intel-nuc.html) for Intel® NUC9i7QNX?
Steven G.
We would like to know if you were you able to check the previous post.
Steven G.
