Intel® NUCs
Assistance in Intel® NUC products
13320 Discussions
Latest "Intel® Graphics DCH Driver for Intel® NUC Kit 11th Gen" breaks NUC11PAKi5 displays
vukawensa
I install the following update, 30.0.101.9999, this morning and my NUC could no longer detect two displays and the same content was displayed on both. Reverting to what I had previously, 30.101.1191, got things working again.
lucasmason
I have the same issue on my NUC11TNKv7 after installing the latest DCH driver 30.0.101.9999.
The driver seems to have a Digital Signature issue:
azdust
Same exact issue here.
Steps to replicate?
Simple - install and run the Intel® Driver & Support Assistant
Install the recommended driver 30.0.101.9999.
David_G_Intel
Hello vukawensa
Thank you for posting on the Intel️® communities. Please share more information with us to investigate this:
  • Steps to replicate the issue.
  • Picture or video examples.
  • Intel® System Support Utility (Intel® SSU) results
David G
lzs
I have the same exact problem. Device Manager says the digital signature of this driver cannot be verified. So it seems basically the driver is not used at all.
qOvop
Same issue, but the universal 30.0.101.1191 driver installed, my problem solved.
lzs
Just curious, bu insstalling the universal driver, does it cause some confusing with Windows/Intel Driver & Support Assistant about your update status? Previously when I tried to install a universal DCH driver (some months ago), the driver will later get "downgraded" back to the official NUC one.
David_G_Intel
Thank you all for the feedback. If you can send us the information mentioned in our previous post, it would help us with the investigation process. As soon as I have any updates, they will be posted on the thread.
David G
lzs
Would be happy to share the info, but is there somewhere I can send the Intel SSU results? Since it contains MAC and serial numbers I rather it not be published openly.
FWIW, mine's a NUC 11 kit i7: NUC11PAHi7 (not totally identical to the OP's). Windows 11 Pro. NUC drivers/software fully updated.
lzs
Just to further add on.
Yesterday, when the Intel® Driver & Support Assistant webpage showed an update for the graphics driver, the "Learn more about this update" led to a page that listed GFX-Win11-30.0.101.9999.zip ( know because I still have the downloaded file). But the same link today goes to Intel® Graphics DCH Driver for Intel® NUC Kit 11th Gen listing GFX-Win10_11-30.0.100.9929.zip for download.
I tried this new GFX-Win10_11-30.0.100.9929, installs fine. The Intel Driver & Support Assistant still says I have an update. I suppose "30.0.101.9999" is indeed newer than "30.0.100.9929".
lucasmason
It seems Intel has removed 30.0.101.9999, and instead listed 30.0.101.9929 dated 16/12/2021.
I have already installed the generic 30.0.101.1191 driver and when trying to install 30.0.101.9929, the installer says I have a newer version already installed. How can 1191 be newer than 9929??
vukawensa
ditto:
and this what currently have:
lzs
I think clearly Intel must have mucked up their upgrade.
Just an observation: The GFX-Win10_11-30.0.100.9929 I installed manually feels not as "smooth". Window animations clearly stutter, definitely worse than the 27.20.100.8935 verrsion I had originally.
Ronny_G_Intel
Community Manager
Hi everyone,
I apologize for the inconvenience, we got a few customers reporting this issue and we have mixed results when trying to replicate so we are removing GFX driver 30.0.101.9999 from the Download Center, please stay on version 30.0.101.1191 https://www.intel.com/content/www/us/en/download/19344/intel-graphics-windows-dch-drivers.html.
Ronny G
lucasmason
@Ronny_G_Intel
Stay on 30.0.101.1191?
What about the NUC11 specific 30.0.100.9929, released on 12/16/2021?
Ronny_G_Intel
Community Manager
Hi @lucasmason
I guess I phrased incorrectly, too many driver versions I guess.
Driver 30.0.100.9929 should be fine to stay with or you may also try 30.0.101.1191 which I tested and works well.
Thanks for pointing this out.
Ronny G
lucasmason
Thanks @Ronny_G_Intel
What are the differences between these two driver versions?
Also can I take this opportunity and ask why two driver branches? One generic DCH driver and one NUC specific?
Why are you asking NUC customers to stay on the generic DCH driver when a revised version of the NUC specific one is available?
Ronny_G_Intel
Community Manager
Hi @lucasmason
The reason for having "two different" drivers is simple: one is the generic driver provided by the Graphics Team and the other one we have for the NUC systems is basically the same driver but tested and validated by the NUC team for NUCs only. Having said that, the NUC driver branches from the generic DCH driver.
I asked customers to run the latest generic because I tested 30.0.101.9999, replicated the issue, and got it resolved by loading the generic 30.0.101.1191, I should have recommended version 30.0.100.9929. I guess I tried to come up with a solution as fast as possible.
Ronny G
