Intel® NUCs
Assistance in Intel® NUC products
All support for Intel® NUC 7 - 13 systems is transitioning to ASUS. Read more.
13511 Discussions
Looking for a stand alone installer to uninstall Intel BT software that is corrupt.
Riverfreddy
My BT software is corrupt. I need to uninstall it and reinstall it. unfortunately, the installer is corrupt and I need to get a stand alone uninstaller. Does Intel have
something that I can use? Ive tried to repair the application but it will not repair.
AlHill
What is the model number of your NUC?
You asked this same question back in December.
Download, run, and ATTACH (using the paperclip under the toolbar) the results of this utility:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Doc
LeonWaksman
  1. You may try to remove the corrupted driver with the inbox tool  pnputil
  2. Open the Administrative Command Prompt and run pnputil -e > C:\drivers.txt
  3. Open the file drivers.txt and look which .inf file is associated with the driver you want to remove
  4. Run pnputil.exe -d oem<NUMBER>.inf (where NUMBER is the number of the relevant inf file)
Leon
