Intel® NUCs
Support for Intel® NUC products
The Intel sign-in experience is changing in February to support enhanced security controls. If you sign in, click here for more information.
12538 Discussions
M.2 Storage for NUC7I7BNHX1
sGold6
Hi everyone. I'm thinking of buying a NUC7I7BNHX1 but have the following question:
If there is only 1 M.2 slot, and it is taken by the pre-installed 16GB Optane memory, how are we to install a NVME disk? I'd much rather have an NVME disk than a SATA disk.
n_scott_pearson
Super User Retired Employee
Sam,
The Optane module is only of value if your boot (and Windows System) device is actually a (spinning media) HDD that the Optane module can accelerate the performance of. If you want your boot/system device to be a super fast NVMe SSD, then you really don't want to pick a model of the NUC that will cost you more because it includes an Optane module, when you will just have to rip out this module to install this SSD. Look for the base model (NUC7i7BNH, or perhaps where you are it's called the NUC7i7BNH1) which should be cheaper...
Hope this helps,
sGold6
As I thought. I did notice the NUC 8 series does have 2 M.2 ports. Thx
n_scott_pearson
Yea, one for that 256GB System SSD and one for that 2TB Data SSD... ;^)
