Intel® NUCs
12118 Discussions
Memory Upgrade From NUC7I7BNH to NUC8I7BEH
TheDigitalJockey
Hello all,
I currently have an Intel NUC7I7BNH and I’m thinking about upgrading to an Intel NUC8I7BEH.
The thing is that the NUC 7 uses 2133MHz memory and, according to Intel specs, the NUC 8 only accepts 2400MHz memory, except when you browse through the compatibility list and see a couple of 2133MHz memories.
What’s the deal with that?
n_scott_pearson
Super User Retired Employee
Any time ​Intel talks about a maximum supported speed for memory, all lower speed bins will work fine and are supported too.
TheDigitalJockey
The funny thing is that some models, like the NUC7I7BNH says it supports 1866MHz and 2133MHz but the NUC8I7BEH and other NUC 8 models only mention 2400MHz memory.
n_scott_pearson
You're reading too much into it. There's a maximum validated ​(and warranted) speed and everything less is implied if not stated as being supported.
TheDigitalJockey
Thank you very much for the clarification. I’m learning something new everyday in this forum.
