Community
cancel
Showing results for
Search instead for
Did you mean:
OM_
Microphone 'not plugged in' issue
Jump to solution
Hey
My microphone is connected to my NUC6i5SYH thru the front 3.5mm jack.
It repeatedly goes from properly working to to 'not plugged in' every few say few hours or mintues (Win10).
Does anyone encountered this problem? any solution?
Thanks!
LeonWaksman
First off all, check if you have the latest Audio Driver installed: https://downloadcenter.intel.com/download/26329/Realtek-High-Definition-Audio-Driver-for-Intel-NUC-K... Download Realtek* High Definition Audio Driver for Intel® NUC Kits . If not, download the zipped driver, unzip it and install.
Secondly check if the plug on your microphone (or headset) meets the requirements defined in Product Technical Specification, para.1.9: https://www.intel.com/content/dam/support/us/en/documents/boardsandkits/NUC6i5SYB_NUC6i3SYB_TechProd... https://www.intel.com/content/dam/support/us/en/documents/boardsandkits/NUC6i5SYB_NUC6i3SYB_TechProd... . If you have connected to the same socket nonamplified speakers, try to test your microphone after disconnecting those speakers.
Leon
LeonWaksman
Leon
OM_
Thanks Leon, I had a different driver that I assumed was automatically installed by WIN10,
Download the driver you suggested and after tweaking it seems to work, thanks!!
(Tweaking details: after installing I got peculiar 'stereo mix' under the sound>recording devices.
I had to unplug and re-plug and then on the realtek dialog choose Mic (later changed to Headset) in order to see the mic on this list)
Ophir
LeonWaksman
Hi Ophir,
I'm glad that your mic is working now. My advice to you is to install all the latest drivers and latest bios version from Intel's site: https://downloadcenter.intel.com/product/89190/Intel-NUC-Kit-NUC6i5SYH Downloads for Intel® NUC Kit NUC6i5SYH . The assumption that every thing is installed automatically by Windows may be wrong. Install all driver manually (do not use Intel Driver and Support Assistant which is not fully debugged). Start with the Chipset and Management Engine Drivers. Reboot and install all other drivers, reboot once the last driver is installed - the sequence of installation is not important.
Leon
OM_
Yes I actually started with the bios, didn't help but I guess was wise to update anyway.
Yes it may be good practice to install all drivers, tho things now seem to work fine so not clear if that's of real importance
(well, maybe it could prevent future mishaps)
LeonWaksman
Hi Ophir,
At least Chipset and Management Engine Drivers is important to install. Having those drivers updated, Windows 10 is be able to update your computer with all the others (however not always with the latest version).
Leon
