Community
cancel
Showing results for
Search instead for
Did you mean:
TBrud
Microphone?
Jump to solution
Does the KYK NUC have a built-in microphone?? I want to add a Webcam (old one) to my NUC for skype chats, but now I don't if I have a microphone for audio!
//Brew
LeonWaksman
I assume that your question is about NUC6i7KYK.
The answer is that NUC6i7KYK doesn't have build-in microphone. External microphone/headphone can be connected trough 3.5 mm jack on the front panel. An other option is to use microphone/headphone with Bluetooth connection (this is what I'm doing). Additional alternative is to connect webcam with microphone trough USB connection. This is example of such camera: https://www.amazon.com/Logitech-Webcam-Portable-Calling-Autofocus/dp/B004WO8HQ4/ref=sr_1_2?ie=UTF8&q... https://www.amazon.com/Logitech-Webcam-Portable-Calling-Autofocus/dp/B004WO8HQ4/ref=sr_1_2?ie=UTF8&q...
Hope this helps
Leon
LeonWaksman
Hope this helps
Leon
TBrud
Perfect, thank you!
