Intel® NUCs
Support for Intel® NUC products
Do you have improvements you would like us to make on this community site? If so, we would love to hear your feedback! Click here for an 8 question survey. Thanks!
11442 Discussions
Mini PC - Intel® NUC Board DE3815TYBE
SSiva5
"Secure UEFI boot issue"
I bought a "Mini PC - Intel® NUC Board DE3815TYBE". Both legacy and UEFI boots works fine. When i disable legacy in the BIOS set up. still OK (boots with UEFI). Once I enable secure boot in UEFI, nothing is happening. Even i cant see the BIOS menu (after holding F2). If i take out the secure boot option, then i can see the BIOS screen.
I tried secure boot with default keys as well as cleared all the keys. Anyone can help me here?
Sen
IUman
Hello Sen33,
I set up this Intel® NUC to see if we get the same behavior and the system worked fine from our end when I have the secure boot enabled.
I'm using the BIOS version 0043 which is one previous to the latest.
At his point I strongly recommend doing a BIOS recovery to this BIOS version, you can download it at:
https://downloadcenter.intel.com/download/24886/BIOS-Update-TYBYT10H-86A- https://downloadcenter.intel.com/download/24886/BIOS-Update-TYBYT10H-86A-
For BIOS Recovery Update Instructions please follow the steps at:
http://www.intel.com/support/motherboards/desktop/sb/CS-034524.htm http://www.intel.com/support/motherboards/desktop/sb/CS-034524.htm
I look forward to hear from you!
IUman
Hello Sen33,
SSiva5
Thanks for the update. It works, but we moved to http://downloadmirror.intel.com/24567/eng/NUC5i3MYBE_TechProdSpec05.pdf NUC5i3MYBE.
Sen
IUman
Thanks sen33 for your reply, I hope the Intel® NUC Board NUC5i3MYBE works good for you.
Regards!
