Hello TJens7,
Thank you for posting on the Intel* community.
We would like to gather more details to better assist you. Please provide us with the below information:
- What is the specific version of Google Chrome you're using?
- How are you connecting the display (s) to the Intel* NUC? Please include the video ports and if you are using a straight-through connection or adapters.
- Is the issue only with Amazon * Prime Video? If you test with a YouTube* video or for example Netflix* the video runs fine?
- Clear steps to reproduce this issue. Please try to include pictures or a video
Please run the following tool and attach the report generated.
Intel® System Support Utility (Intel® SSU)
- Intel® SSU Download
- Open the application and click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View".
- Click on the menu where it says "Summary" to change to "Detailed View".
- To save your scan, click on "Next", then "Save".
Maria R.
Hello TJens7,
Let me know if you need more assistance.
Maria R.
I had seen it and had typed out a lengthy reply to have the autosave fail and loose my reply.
I reinstalled Windows and Chrome. I only mentioned Prime Video because I open and close tabs in it frequently, but it also does it occasionaly browsing forward or backward in any site. Typically the right monitor, also the right HDMI port by the power, will blink, sometimes the left monitor will blink, and sometimes both
Also as well, default power settings for Windows, the computer would go to sleep after default amount of time, attempting to wake, nothing comes on the monitors and requires cycling power to bring back on.
I set sleep time to never, however with the monitors set to go off after a time, frequently only one monitor will come back on requiring a shut down and powering on again to bring back both monitors. Further on this, sometimes upon rebooting the POST screen will only be on one monitor and I have to unplug the NUC and hold the power button for 30 seconds and then output on both HDMI ports is restored.
This NUC is replacement from a previous NUC replaced under warranty, I believe this NUC is having hardware issues.
Attached is the SSU report.
The unit is under warranty, I have submitted a support request.
Hello TJens7,
Thank you for let us know.
Since you opened a ticket with Intel® Customer Support directly regarding the same issue here described, to avoid duplication of effort, we want to know if you prefer to continue the support using the Community Forums or if you prefer to close this thread.
Please let us know.
Maria R.
Being it's under warranty I'll continue with the support ticket in case a return is needed.
You can close this ticket.
Thanks!
Hello TJens7,
Thank you for let us know!
If you need any additional information, please submit a new question as this thread will no longer being monitored.
Maria R.
