Intel® NUCs
Support for Intel® NUC products
The Intel sign-in experience is changing in February to support enhanced security controls. If you sign in, click here for more information.
12545 Discussions
Monitors turns off and on when fan speeds increases
Anonymous
Not applicable
I have an Intel Nuc i7BNH, I had problems with the monitor flickering on and then off since I purchased it. The monitor is a LG24UD58 4k. Initially the monitor made things worse because of a dark color mode feature that was enabled. Things improved when I disabled the feature. I updated all the bios, display drivers, and software updates. Still no improvement. Now, I notice a correlation, when the fan speed kicks into higher gear it causes the monitor to turn off for a second or two and then turn back on. I'm not really using any resources that should cause the fan to kick into its highest gear, mainly streaming, office work no gaming.
Labels (2)
LeonWaksman
1. What happen if you connect your NUC to other monitor (for example to TV set)?
2. Try to use other HDMI cable.
Leon
Anonymous
Not applicable
1.) When I removed the NUC from the back of the monitor and I move it away and place it on the desk, it was attached directly with the VESA plate, the problem seems to be fixed.
-Couple of things I notice: the fan blows hot air directly past the hdmi port/cable. So, the cable input gets hot. I thought it could be related to the CPU fan increasing speed, the CPU using more resources, and the hot air blowing on the cable insert. I'm not sure if this is important because the cable is still there when I place the nuc on the surface. I'm not seeing this issue, as of now.
-Could the vesa mount, being directly on the back of the monitor and some emi interference from the nuc be causing the monitor to flicker?
2.) Replacing the hdmi was the first step, which didn't fix the issue.
Alberto_R_Intel
Hello capreg, Thank you for posting in the Intel® Communities Support.
In reference to this scenario, just to let you know, the Intel® NUC Kit NUC7i7BNH is under the status of End Of Interactive Support / Discontinued as you can verify in the link below:
https://ark.intel.com/content/www/us/en/ark/products/95065/intel-nuc-kit-nuc7i7bnh.html
So, Intel® technical support will no longer be provided for this kind of product, but perhaps fellow community members have the knowledge to jump in and help. You may also find the Discontinued Products Website helpful to address your request:
https://www.intel.com/content/www/us/en/support/discontinued-products.html
Albert R.
Anonymous
Not applicable
So, it just happened a few minutes ago. I checked the windows event log and found this error message: The event logging service encountered an error (res=1500) while initializing logging resources for channel Microsoft-Windows-WerKernel/Operational.
What does this mean? What should I check?
