Community
cancel
Showing results for
Search instead for
Did you mean:
FRoyl
Motherboard temperature 123 degrees but appears to be functioning OK.
It's a fairly old NUC but still works well - Motherboard: Intel Corporation D34010WYK (CPU 1) 123 °C
Is this a problem and if so what may be the solution
LeonWaksman
Hi @FRoyl
Working in such high temperatures indicates failure in the cooling solution. Your NUC will be damaged.
Is the Cooling Blower working? Can you hear it? I suggest that you should clean the Thermal Solution including the Cooling Blower. Since all this is installed on board upper ( the invisible site), you need to remove board from the case in order to reach the blower. This video may help you (you may start  watch from 8:10)
Leon
n_scott_pearson
Super User Retired Employee
In this case, I believe that what has happened is that the thermal diode that is used to sense the temperature on the motherboard has failed. Seeing a static temperature like this is the usual sign of this issue. There is little that you can do about this type of failure. Since ensure that you are not having any fan speed control decisions made based upon this sensor. Using the Memory Temperature sensor in place of the Motherboard sensor offers a similar response curve.
Hope this helps,
David_G_Intel
Hello FRoyl
Thank you for posting on the Intel️® communities.
Due to this product being discontinued, Intel Customer Service no longer supports inquiries for it, I am glad to see that fellow community members have the knowledge and they jumped in and helped.
You may also find the Discontinued Products website (https://www.intel.com/content/www/us/en/support/discontinued-products.html) website helpful to address your request.
You can get the specifications and verify this product's discontinuance status at the Intel® Product Specifications website > Product Status > "Discontinued". https://ark.intel.com/
Please keep in mind that this thread will no longer be monitored by Intel. Thank you for your understanding.
David G
Intel Customer Support Technician
