Hi folks,
since Sep, 30th I found 50+ error events of this type, always in pairs.
- <</span>Event xmlns=" http://schemas.microsoft.com/win/2004/08/events/event"> - <</span>System> <</span>Provider Name="ESRV_SVC_QUEENCREEK" /> <</span>EventID Qualifiers="16384">2</</span>EventID> <</span>Level>2</</span>Level> <</span>Task>1</</span>Task> <</span>Keywords>0x80000000000000</</span>Keywords> <</span>TimeCreated SystemTime="2017-10-12T15:01:21.620858900Z" /> <</span>EventRecordID>209</</span>EventRecordID> <</span>Channel>ESRV_SVC_QUEENCREEK</</span>Channel> <</span>Computer>NUCLEUS</</span>Computer> <</span>Security /></</span>System>
- <</span>EventData> <</span>Data>Error [0]: [Invalid Parameter(s).][0x57]. Problem: [--RUN_AS_USER_PROCESS]. Solution: [Unknown Command.]. Occurred: [Thu Oct 12 17:01:21 2017]. In file: [parse_cli.c]. At line: [774].</</span>Data></</span>EventData>
</</span>Event>
and
- <</span>Event xmlns="<a class="jive-link-external-small" href=" rel...Link Copied
Look at the correct answer in this thread:
Doc
Hi Doc,
thanks for the link.
For the moment I have removed (uninstalled) the tool.
Reinstallation (with the 'special' option ) will take place tomorrow.
Holger
