Intel® NUCs
Assistance in Intel® NUC products
All support for Intel® NUC 7 - 13 systems is transitioning to ASUS. Read more.
13496 Discussions
My 3.0 USB plug won't work. I can charge my phone with it but won't transfer info.
BHend11
It says I have driver error. When I check the drivers it says I have the latest one I keep getting error 31.
LeonWaksman
Check in BIOS settings (Devices > USB) that all USB ports are enabled.
Leon
BHend11
I dont know how to check the BIOS
LeonWaksman
You didn't provide any information about your computer. If it is Intel computer ((for example NUC), I can help. Otherwise, I suggest that you should read User Manual for your computer or ask the computer manufacturer support.
Leon
BHend11
Its a Laptop, Asus N537V gaming notebook computer. It has Itel software for sure.
BHend11
Im using Windows 7 professional. The 3.0 USB was installed and working fine a couple of months ago.
LeonWaksman
The USB 3.0 is not a part of Windows 7. Try to connect an older device working with USB 2.0. If it works, the problem is in the USB 3.0 driver. You need to reinstall it. BTW, are you aware that upgrade from Windows 7 to Windows 10 (which includes the USB 3.0) is free and very easy?
Leon
BHend11
Yes, I found that out recently on Microsofts web site. I figure Id get the Geek Squad to help me because I dont want to mess anything up.. I just had to back everything up first. Thanks for trying to help me.
My 3.0 USB plug was installed in my Asus laptop and working until recently. If I check the Device manager it shows it there, but that the driver needs to be updated. When I try to update the driver it says I have the latest driver installed and then I get an error message 31. Even my windows program cant fix the problem it finds the problem but says the drivers are missing. The 3.0 USB plug will only work as a charger for my phone, but I cant charge my ipad with it.
When I plug my external harddrive into one of the other 2.0 USB I get the message that it would be faster with a higher USB.
I dont have the manual for it.
LeonWaksman
  1. I can't find your laptop in Asus site. So, I can't help to find the USB 3.0 driver.
  2. However if you decide to upgrade to Windows 10 (you better create backup of your drive first), please read this tutorial.
Leon
