Intel® NUCs
12111 Discussions
My Dual Core Intel Core 2 Duo is paralyzed !
JCall10
Hi !
My PC when I use it is paralyzed for one or two minutes and then continues, and so continuously for a very short time.
I did a test with the Intel Processor Diagnostic Tool and I got an error:
CPU 1 - BrandString - Fail
Temperature all ok
What does this error mean to me?
Motherboard:
DualCore Intel Core 2 Duo E6420, 2133 MHz (8 x 267)
XFX MB-N650-IUL9 (3 PCI, 2 PCI-E x1, 1 PCI-E x16, 4 DDR2 DIMM, Audio, Gigabit LAN)
nVIDIA nForce 650i Ultra
4096 MB (DDR2 SDRAM)
DIMM1: Kingston  1 GB DDR2-667 DDR2 SDRAM (5-5-5-15 @ 333 MHz) (4-4-4-12 @ 266 MHz) (3-3-3-9 @ 200 MHz)
DIMM2: Kingston  1 GB DDR2-667 DDR2 SDRAM (5-5-5-15 @ 333 MHz) (4-4-4-12 @ 266 MHz) (3-3-3-9 @ 200 MHz)
DIMM3: Kingston  1 GB DDR2-800 DDR2 SDRAM (6-6-6-18 @ 400 MHz) (5-5-5-15 @ 333 MHz) (4-4-4-12 @ 266 MHz)
DIMM4: Kingston  1 GB DDR2-800 DDR2 SDRAM (6-6-6-18 @ 400 MHz) (5-5-5-15 @ 333 MHz) (4-4-4-12 @ 266 MHz)
BIOS  Award (03/27/07)
Monitor:
GeForce GT 740 (2048 MB)
Multimedia:
C-Media CMI8738/C3DX Audio Device
nVIDIA nForce 430i (MCP51) - High Definition Audio Controller
Realtek ALC885/889A/890 @ Controladora de High Definition Audio [10DE-0E1B] [NoDB]
Thank you
n_scott_pearson
Super User Retired Employee
Error(s) from the Intel Processor Diagnostic Tool is/are expected when testing Core 2 Duo processors. The tool was designed to test the capabilities of the newer Core processors and these older Core 2 Duo processors simply do not have all of these capabilities (and specifically do not support a CPU Brand String).
As for what is causing this paralysis, I have no idea. There are all sorts of things that could be causing this.
JCall10
Good Morning.
Ok, I will continue investigating the problem.
Thank you very much for the help and the prompt response.
Best regards.
