I have an Intel NUC (Intel NUC Mini Compact Portable PC (10th Gen Intel i7-10710U, 32GB DDR4 RAM, 1TB NVMe SSD, 802.11 AX Wireless, Bluetooth 5, Thunderbolt 3, No OS). It seems to run hot from time to time. Once in a great while (once a week on average), it will shut down with a high temp error. Attached are some log files and screen shots showing the system configuration processor tests. I ran a tool called HWmonitor_1.45 to monitor system parameters.
Have you tried using a can of compressed air to clean out the dust and dirt buildup? Blow air in via every set of openings, especially the ones you can see the black heatsink fins through.
If this doesn't work, (carefully!!) remove the motherboard from the chassis. Then, remove the blower (two or three small screws) so that you can clean out the buildup at the heatsink that couldn't be blown out via compressed air. Do the inside of the blower itself as well.
A man's best friend:
Hope this helps,
Thanks! The inside was very clean when I opened it. I did notice however, that a stickers on the SSD had come lose and was restricting some air flow. in the last 12 hours, the cpu temps were never above 65C
I should add that you should be doing this about every 3 months. More often if in a dustier environment.
And this goes for all of your other electronic equipment.
