After hdmi firmware update, my Intel NUC7i5BNH Hdmi not working event on Bios screen. I already tried diffrent monitor and hdmi cable. What can I do?
Rerun the firmware update again. Before starting, read the User Guide
You may try this update using the BobcatISP.exe -run command in the Administrative Command Prompt.
Leon
I would add that, if you cannot see to rerun the update, you may need to use an adaptor to connect your monitor to the USB-C connector.
