My i7 Gen10 NUC Cannot make a scheduled power on. I cannot activate the system wake up at S5 state function in the BIOS settings please help me ASAP. Thank you . (NUC10i7FNB)
I just tested the feature and it worked just fine for me. Please explain exactly what you did, step by step, to configure the capability.
1. Turn off fast startup in the power settings
2. Change SATA Mode selection from intel RST premium to AHCI (That makes me be able to setup the schedule wake up but I cannot startup my OS)
Why did you have it set to RST Premium? Are you using RAID? Are you using Optane? If not, don't enable it at all!
If you had it set to RST Premium when you installed Windows 10, then Windows 10 is no longer going to be able to boot when you set it back to AHCI. In this case, boot into Windows Safe Mode. Once loaded, you should be able to then shut down and subsequently boot properly.
Fast Startup in Windows power settings is not going to make a difference. I have it enabled and can still use scheduled power on.
