Intel® NUCs
Assistance in Intel® NUC products
All support for Intel® NUC 7 - 13 systems is transitioning to ASUS. Read more.
13485 Discussions
My new Intel Nuc 10iFNH3 will not recognise my Displayport monitor on USB-C Thunderbolt port
loudon3
My new Intel Nuc 10iFNH3 will not recognise my Displayport monitor on USB-C Thunderbolt port. I have all the latest Intel Nuc drivers from Intel. The monitor is a Samsung U32J590 4K monitor on a Displayport 1.2 port, which worked fine with my old Intel Nuc on a straight mini-Displayport to Displayport connection. I have the correct Samsung monitor driver for Windows 10 installed. The monitor works fine in 4K x 60Hz on the HDMI 2.0a connection. I bought this Intel Nuc so I could have 2 x Displayport monitors at the same time, one on HDMI 2.0a and one on Displayport 1.2 via USB-C Thunderbolt. Thunderbolt is enabled in the Intel Nuc BIOS. Any ideas on how to fix this one, please?
DeividA_Intel
Hello loudon3,
1. Run the Intel® System Support Utility (Intel® SSU) to gather more details about the system.
· Download the Intel® SSU and save the application on your computer:  https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
· Open the application, check the "Everything" checkbox, and click "Scan" to see the system and device information. The Intel® SSU defaults to the "Summary View" on the output screen following the scan. Click the menu where it says "Summary" to change to "Detailed View".
· To save your scan, click Next and click Save.
2. Are you using the USB-C from the back of the unit?
3. Have you updated the BIOS?
4. Are you using an adapter (for example, to convert Thunderbolt from the Intel NUC to DisplayPort on a television)?
5. Have you updated Windows, including optional updates?
6. Are you having display with the USB-C cable or not at all?
Deivid A.
loudon3
1. SSU report attached below.
2. There is no USB-C on on the back of the unit on a 10i3FBH - just one on the front of the unit.
3. No I have not updated the BIOS.
4. No, I am just using a direct USB-C to Displayport cable to my Samsung UHD monitor. This cable and monitor works perfectly well with my Windows 10 laptop.
5. Yes, I have installed all Windows 10 updates, excluding the optional update. I will now install the optional update also.
6. I am using a standard USB-C to Displayport cable to connect to my Samsung UHD monitor - this works perfectly on my Windows 10 laptop but is not recognised on my Intel Nuc.
I look forward to a solution to this problem - thanks for the prompt reply.
Best regards
Paul R Hynd
_____________________
DeividA_Intel
Hello loudon3,
Based on the report and the information provided, please try the following:
1. If you have an Intel® NUC 10 Performance kit - NUC10i3FNH, please use the USB-C with a "Thunder" symbol next to it. based on the datasheet you should have 2 USB-C for video (thunder symbol) and data/storage (with no thunder symbol)
- Datasheet (page 52 and 53): https://www.intel.com/content/dam/support/us/en/documents/intel-nuc/NUC10i357FN_TechProdSpec.pdf
2. Update graphics drivers:
- Driver: https://downloadcenter.intel.com/download/30381/Intel-Graphics-Windows-10-DCH-Drivers?v=t
3. Bios recovery:
- BIOS (FNCML357.0052.RECOVERY.zip): https://downloadcenter.intel.com/download/30404?v=t
- Steps: https://downloadmirror.intel.com/30404/eng/NUC-AptioV-UEFI-Firmware-BIOS-Update-Readme.pdf
Deivid A.
DeividA_Intel
Hello loudon3,
Were you able to check the previous post and try the recommendations? Please let me know if you need more assistance.
Deivid A.
DeividA_Intel
Hello loudon3,
We have not heard back from you, so we will close this inquiry. If you need further assistance or if you have additional questions, please create a new thread and we will gladly assist you.
Deivid A.
