Intel® NUCs
11784 Discussions
NIC8i7HVK plantronics headset microphone.
JGumk
I am having issues getting my Plantronics blackwire 520 headset microphone working. All intel nuc drivers/bios, and plantronics headset drivers are updated to the latest version. The headset connects and identifies just fine, but the microphone will not work. The audio comes through the headset fine, but input will not work with the microphone.
LeonWaksman
  • The headset is muted. Press the mute button to unmute the microphone.
  • The headset is not set as default audio device on your computer. Set the headset as default audio device in your computer.
  • Enter Settings> Update @ security > Troubleshoot>Speech and run the Troubleshooter
Leon
JGumk
Thanks. All of these have been validated and still not working.
LeonWaksman
Is the headset connected directly to one of USB inputs or, it is connected to an USB hub?
Leon
RBell1
FWIW (not much), my Plantronics Blackwire 725 works correctly with my NUC8i7HNK.
