Intel® NUCs
12341 Discussions
NUB8i5BEH2, Charging usb port always on.
tbarr7
hi,
How can i disabled the power of front charging usb port when the computer is off ?
I have try with BIOS (last version BECFL357.86A.0078) but with the bios param : Portable Device charging mode = Off, the out power keep on.
LeonWaksman
Can't check on your NUC. On NUC8i7HVK however, setting Portable Device charging mode to Off, disconnects the power from the charging USB port (yellow) in S5 power state. In order to disconnect power in S5 from all other USB ports (blue ports), the parameter USB S4/S5 Power in Power tab should be unchecked.
Lets see if some user with NUC8ixBEx may confirm your findings. If yes, the problem is in BIOS.
Leon
tbarr7
Thanks for your answer, but i have find a problem, i need to check the DEEP S4/S5 box !
LeonWaksman
You want to say that you needed to uncheck the DEEP S4/S5 (disable)? FYI, the Portable Device charging mode = Off is working in my NUC with DEEP S4/S5 disabled.
Leon
