Intel® NUCs
Assistance in Intel® NUC products
13314 Discussions
NUC 10 3.5mm audio jack is now working
area-concierge
I had posted a question earlier about the 3.5 mm jack not working due to a BIOS update. I can now confirm that the solution posted here:
https://community.intel.com/t5/Intel-NUCs/NUC10i5FNH-doesn-t-recognise-3-5mm-Audio-Out/td-p/1238315
... is working. The thread is now closed as I could not troubleshoot and respond in time. However, I thought I should mention that the fix worked just in case it helps.
For anyone trying to fix the same problem, please follow the instructions to flash the BIOS fully.
LeonWaksman
Hi @area-concierge
I understand that updating BIOS using BIOS Recovery method, solved this problem?
Leon
