Intel® NUCs
Assistance in Intel® NUC products
13319 Discussions
NUC 10 i3 SATA boot only after pressing F10
svenry
SATA SSD with Windows 10 boots only when i press F10.
Without i get mesage "a bootable device had not been detected"
How do i get automatic booted into Windows?
I dont see any SATA boot order in the BIOS
SSD is shown in storage menue
BIOS is latest one and restore defaults was also done
any idea?
svenry
i solved the strange behaviour:
plugged in an usb drive
press F10 and usb and SSD is selectable
went into BIOS and checked boot order and there are two options. set #1 to SSD and #2 to USB drive
save settings
unplugged USB drive
bootet from SSD
Issue solved :-)
LeonWaksman
  1. Install Windows 10, using the following steps:
  2. Please prepare your installation media (you need 8GB – 32GB USB stick), using Microsoft Media Creation Tool.
  3. Your bios should be set to default settings. Enter bios (press F2 during boot) and then press F9 (Y) to set defaults and F10 (Y) to save settings and exit.
  4. With the installation media inserted into rear USB slot, power ON your NUC and repeatably press F10 to get Boot Menu.
  5. In this menu, choose UEFI option of you Installation media.
  6. Follow this tutorial to continue with installation https://www.tenforums.com/tutorials/1950-clean-install-windows-10-a.html
  7. In para. 7 you may enter Product Key from the Microsoft Distribution you bought.
  8. Skip on para. 12 and continue in para. 13. Important, do not format drive where you want to install Windows, rather delete all existing partitions from this drive, till you see one unallocated space.
  9. Press Next and continue with the installation.
Leon
svenry
save settings
unplugged USB drive
bootet from SSD
Issue solved :-)
