A few of the larger / taller NUC cases have the hole at the back base to install expansion, we want to CAD design and 3D print a plate for this, does Intel have the technical details (dimensions) of the hole and screw locations?
https://www.intel.com/content/dam/support/us/en/documents/intel-nuc/NUC11TN_TechProdSpec.pdf#page=21
Page 21 (section 2.1.6)
Many Thanks
Mechanical drawings for the NUC products can be found here: Intel NUC Element Mechanical Drawings. I do not currently have setup to view STEP drawings, so can not tell you if the information you require is there. If it is not, let us know here.
Hope this helps,
Hi, thanks for the link. Those are for the NUC Element, the above product is not part of that line... so those files do not contain the dimensions we would need.
Hello GRIFFCOMM,
We have another website with Mechanical Drawings for Intel® NUC, which it is listed the STEP-based files with the Intel® NUC Kit Drawings. Your Intel® NUC product is part of the list. Let me know if this file helps you with your requests.
https://www.intel.com/content/www/us/en/support/articles/000006820/intel-nuc.html
Jean O.
Oops, sorry; grabbed the wrong link :^(
Hello GRIFFCOMM,
I hope you are doing fine.
Jean O.
Hi
Still reviewing, will know more over the weekend.
Hello GRIFFCOMM,
I understand that you are still reviewing the files. Let me know if you face any issues.
Jean O.
Hello GRIFFCOMM,
Jean O.
Hello GRIFFCOMM,
I have not heard back from you. So we will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jean O.
Hi
The link for the files of the cases do seem to contain what we require, this is really helpful, we are looking at the files in more details now.
Many Thanks
Hi
As an update, i thought i would post what we did, we have orders for the BNUC11TNHI5 which is the tall case with a blank, with the help of the STEP file as guidance we created a new blank which will then be filled with a D-Sub connector, the below is the complete prototype, still waiting for the D-Sub connectors to complete the design.
: i know the metal plate has the knocks outs in it but we like a very finished polished product when we sell them.
