Intel® NUCs
Support for Intel® NUC products
12734 Discussions
NUC 11 Pro does not enter hibernation (S4) reliably
carlfriedrich
I have a NUC11TNK with an i7-1185G7 CPU running Windows 10. My problem is that in ~ 4 out of 10 times my system won't enter hibernation mode correctly. At first everything seems to be done correctly: the OS is shut down, the screen goes blank. But then the device just does not power off, i.e. the power LED stays lit. Pressing the power button or any buttons on the keyboard do not have any effect in this state. The only way to get out of it is either plugging out the power cord or 10-sec-long-pressing the power button to force power-off. Afterwards the system will not wake up from USB (which I normally use) but only from the power button.
I have tried disconnecting my USB devices in order to check if any of those keeps the device awake, but even with none of them connected the error stays the same.
I also tried disabling all unneeded onboard components in the BIOS and played around with several other BIOS options. The error still persists, even with "Deep S4/S5" enabled.
My hardware:
  • RAM: 2x Kingston HyperX Impact 8GB DDR4-3200 CL20 (HX432S20IB2/8)
  • SSD: Western Digital Blue SN550 M.2 2TB M.2 (WDS200T2B0C)
  • Monitor: ASUS VX24A via HDMI
  • Mouse: Microsoft Bluetooth Ergonomic Mouse
These are the only parts I am using on my NUC, nothing else connected.
Does anybody have an idea what prevents the system from powering off correctly when entering hibernation? Any clues what I could check or try?
carlfriedrich
Hi @DeividA_Intel,
thanks for your reply. The good news is that I was already able to resolve this issue. I did some testing with live Linux environments on USB drives and tested hibernation from there, which was working correctly in 100% of all times. So I assumed that my NUC and the BIOS settings are okay, and the cause must be either my hard drive or my Windows installation.
I searched the internet for Windows hibernation problems in general and stumbled upon this thread from a Microsoft forum:
https://answers.microsoft.com/en-us/windows/forum/all/windows-10-freezes-after-shut-downsleephiberna...
The answer by DannyLive fixed the issue for me! I disabled the power management setting "Allow this computer to turn off this devie to save power" on the "Intel(R) Management Engine Interface #1" device in my device manager:
I tried hibernating 30 times with this setting disabled with not a single failure now.
So in the end this seems like an Intel driver issue? Is this a known bug?
DeividA_Intel
Hello carlfriedrich,
Thank you for posting on the Intel® communities. I understand you are having issues with your NUC11TNK.
1. Run the Intel® System Support Utility (Intel® SSU) to gather more details about the system.
2. Is this issue recent? If so, when did it start?
3. Did you notice the after a systems update (Windows, drivers, BIOS)?
4. Have you noticed any blue screen of dead since the issue started?
Deivid A.
carlfriedrich
Hi @DeividA_Intel,
DeividA_Intel
I am glad to know that you were able to fix the issue by disabling the power management setting,
In this case, we do not have any recent reports of this behavior, however, we have seen this problem before and may be related to the operating system and/or the BIOS.
Since you fixed the issue, I will proceed and close this thread but you can create a new one if you need further support.
Deivid A.
