Intel® NUCs
Assistance in Intel® NUC products
All support for Intel® NUC 7 - 13 systems is transitioning to ASUS. Read more.
13512 Discussions
NUC 2nd Monitor Waking issues
Remock
I work for a company that uses NUC's exclusively, we have many stations with issues waking their second monitors. All drivers have been updated as per Intel's update assistant. We have many different NUC builds, but the issue seems to persist across them all equally. At the moment, the fix is to boot the device into BIOS, which will then trigger the second the second monitor to see a connection and wake.
Things that I've tried that have not worked:
Update all drivers
Update the BIOS
Update the firmware on the monitors
Swap the NUC's
Swap the cables
Swap the monitors
Swap the inputs
We use 3 different versions of the ASUS Pro Art series:
PA24AC - most problems
PA248 - second most problems
WUXGA - no problems
I have seen many dead end forums for this where the resolutions are only workarounds, I am hoping to avoid this kind of solution as it does not work in a corporate environment. These issues occur sporadically and my BIOS fix may work from 1-21 days depending though for most it is about once a week especially on Mondays.
JosueO_Intel
Hello Remock,
Thank you for posting on the Intel communities. In order to have a better understanding of the issue, please share with us the following information:
  1. Was everything working fine before? If so, when did the issue start happening?
  2. Which port are you using to connect the displays?
  3. Are you using any adapters or dongles to connect the displays?
  4. Have you tried using a non-NUC system to test the displays?
Also, please download and install the Intel System Support Utility (Intel SSU):
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
Open the application and select "Everything" click on "Scan" to see the system and device information. By default, Intel SSU will take you to the "Summary View". Click on the menu where it says "Summary" to change to "Detailed View".
Click on "Next", save the report and attach it to your response. Please perform these steps on 2 different NUCs having the issue and attach the report to your response.
Josue O.
Remock
Hey Josue,
1. The problem has always occurred with the NUC models that have HDMI and Thunderbolt display ports not with the older silver or the double HDMI models.
2. We run dual display and it typically is the thunderbolt port that causes issues, but not always making me think it is something related to the broader graphic functionality of the NUC
3. We use only cables in our environment USB-C to DP, USB-C to HDMI, etc.
4. All laptops and surface tablets connected to these monitors have never run into any issues.
See attached reports
JosueO_Intel
Hello Remock,
In this case, after checking both reports we found that there are newer versions of BIOS for both Intel® NUCs. Also, newer version for the graphics driver.
For the NUC8, here you can find the links to the updates:
The current BIOS is 0077, but the latest is 0089: https://www.intel.com/content/www/us/en/download/19303/bios-update-becfl357.html
For the graphics driver, download the latest driver optimized for the Intel® NUC:
https://www.intel.com/content/www/us/en/download/19664/intel-graphics-dch-driver-for-nuc8i3be-nuc8i5be-nuc8i7be.html
Regarding the NUC7, we also found a newer version for both the BIOS and the driver:
For the BIOS, the current version is 0062, however, the latest is 0085
https://www.intel.com/content/www/us/en/download/18838/bios-update-bnkbl357.html
And for the graphics driver, you can download it here:
https://www.intel.com/content/www/us/en/download/19046/intel-hd-graphics-driver-for-windows-10-for-nuc7i3bn-nuc7i5bn-nuc7i7bn.html
Regarding the instructions for these updates, for the graphics driver please perform a clean installation, in order to do this, follow the next steps:
1- Download the latest customized driver.
2- Disconnect from the internet to make sure the driver will not be automatically updated by Windows.
3- Uninstall the Intel Graphics driver. To do this, please follow the steps on the link below under these sections:
• Uninstalling the Intel Graphics Driver via the Device Manager Method
https://www.intel.com/content/www/us/en/support/articles/000005598/graphics.html
4- Restart the computer.
5- Right-click the Windows Start button. Select Device Manager.
6- If no older drivers are stored in the system, the graphics controller in Device Manager should now be listed as 'Microsoft Basic Display Adapter', 'Standard VGA Graphics Adapter', or similar. If not, repeat step 3. Repeat the process until it is listed as 'Microsoft Basic Display Adapter'.
7- Install the latest graphics driver.
8- Once the latest driver has been installed, enable the internet connection again.
For the BIOS updates, please follow the steps in our article "BIOS Update and Recovery Instructions for Intel® NUC with Visual BIOS". Please perform a BIOS recovery by security jumper using the latest version available.
https://www.intel.com/content/www/us/en/support/articles/000005636/intel-nuc.html
Josue O.
JosueO_Intel
Hello Remock,
Josue O.
JosueO_Intel
Hello Remock,
Josue O.
Remock
Was on holiday, I have pushed the suggested changes and will see if this corrects the problem, however, I have attempted this fix before with the exception of the process listed for installing the graphics from the ground up. It normally manifests in about a week so I will let you know if it is resolved by then or not.
Remock
For all the future ppl reading, no this did not work, in fact it broke 6 hours later. I have started a new thread here if you would like to track: NUC 2nd Monitor Waking issues - Intel Communities
