Power on from COLD/ keyboard indicator activates then shuts down after 4 secs system blue led ON continuously. No Video (blank screen)
Remove power/ Restore power computer boots normally and responds normally for the rest of the day including stop/starts.
BIOS updated and restored to latest iteration. might this be a hardware problem
No option to test power cord/adapter except off load voltage 19.4v DC
RAM: Crucial CT8G4SFS824A DDR4 2400 MT/s (PC4 19200) CL17 SR x 2 MEMTEST pass One memory stick test completed with basic config pass
Internal Disk: Samsung 960 EVO (500G) M2 PCI Express 3.0 x4 NVMe Samsung Magic pass
Currently problem is unresolved. Initial Start Cold Boot fail (Symptoms Keyboard Indicator ON Monitor black screen within 5 secs Fan heard within 10 secs No further progress. Immediate restart boot pass. Operation normal
Peripherals tested OK on a laptop: keyboard Mouse Monitor.
Hello @RDavi17
Since your NUC is working good (except the cold start), please ensure that it was completely switched OFF before you leave it for a night.
Please try the following procedure to perform full shutdown from Windows:
Step 1: Open Start menu, select Power button.
Step 2: Press and hold the Shift key on keyboard, while clicking on Shut down, and then release the Shift key to perform a full shutdown.
If after this shutdown, you will be able to power your NUC ON, the problem is in Windows setting.
Leon
Thanks for your intervention but this does not solve the problem.
