The good new is the Infrared driver finally works after all these years although it seems to require line of sight.
MDNY, Thank you for posting in the Intel® Communities Support.
Thank you very much for sharing those updates about the "Infrared driver", we are sure it will be very helpful for all the peers viewing this thread.
In reference to the Wake-On LAN problem, in order for us to better assist you, we just wanted to confirm a few details about your system:
What is the model of the Intel® NUC?
Is this a new Intel® NUC?
When did you purchase it? (For warranty purposes)
You mentioned "After updating the BIOS last week the Wake-On-LAN function failed to work", that means, just to make sure, that it was working fine before the BIOS update, correct?
By any chance, do you remember that BIOS version, when it was working fine?
Did you make any recent hardware/software changes, besides the BIOS update, that might cause this issue?
Which Windows* version are you using?
Albert R.
MDNY, Thank you very much for providing that information and the SSU report.
Based on the information shown in the SSU document, we can confirm that the latest BIOS version 0089 is currently and properly installed on your machine. Same thing with graphics driver version 30.0.101.1660 as well:
https://www.intel.com/content/www/us/en/download/19303/bios-update-becfl357.html?wapkw=nuc8i7beh
Even though you mentioned that the problem started right after the BIOS update, in the following links you will find further suggestions to try to fix this problem, could you please verify those links, and once you get the chance let us know the results?
https://www.intel.com/content/www/us/en/support/articles/000027615/intel-nuc.html
https://www.intel.com/content/www/us/en/support/articles/000033202/intel-nuc.html
Albert R.
Thank you for these ideas, but both did not work. The second link was particularly useless where the article states to go to VMware and check the compatibility for which the article says is compatible in the Resolution section. That is not a resolution.
There are other issues with WOL on this forum and it clearly points to the BIOS. Can I roll back this change or will you be offering a path in the near future and if so when?
MDNY, You are very welcome, thank you very much for confirming those details.
In reference to your question "Can I roll back this change", as you can see in the link below, it states that "Downgrading the BIOS to an earlier version is not recommended and might not be supported."
Still, I will do further research on this matter to confirm that information and also to verify if we will be offering a path in the near future. As soon as I get any updates, I will post all the details on this thread.
Albert R.
Hello MDNY, I just received an update on this matter,
While we are still working on this case, we just wanted to confirm if the box for the option "Allow this device to wake the computer" under the "Power Management tab" is checked.
Based on the SSU report, as you can see below, Wake On LAN is enabled so there is no problem with the feature itself.
Intel(R) Ethernet Connection (6) I219-V
Power Management (Wake On LAN):"Active: Yes, Enable: Yes"
Power Management (Wake on Magic Packet):"Active: Yes, EnableWakeOnMagicPacketOnly: No"
We also recommend testing the Intel® NUC with the Windows Fast Startup feature turned off and installing the latest LAN driver for your machine, version 12.18.9.23:
Albert R.
Hello MDNY, I just wanted to check if you saw the information posted previously and if you need further assistance on this matter?
Albert R.
Not one of the steps work and there still are no driver or bios updates.
On reddit, I recommended a Minisforum brand with an AMD chip over the Intel nuc because this is a terrible experience.
Did you know I can't use my phone to reply to you?
MDNY, Thank you very much for letting us know those results.
We will continue with our research on this matter. As soon as I get more information I will post all the details on this thread.
In reference to the problem about not being able to reply from your phone, you can report that using the email below:
Albert R.
Hi MDNY,
We tested WOL with BIOS version BIOS 0089 and it worked well, see below the scenarios we tested:
WOL from S5 state:
- Ctrl + Alt + Del => Shut down
- Send magic packet via NirSoft* WOL tool [https://www.nirsoft.net/utils/wake_on_lan.html]
- System wakes up, monitor wakes up.
WOL from S3 state:
- Ctrl + Alt + Del => Sleep
- System wakes up (HDD activity LED is active, Power Button LED is solid blue), monitor continues to be in sleep state.
Please check with this tool and let us know the results.
Ronny G
Hello MDNY, I just wanted to check if the information posted previously was useful for you and if you need further assistance on this matter?
Albert R.
Hello MDNY, Since we have not heard back from you, we are closing the case, but if you have any additional questions, please post them on a new thread so we can further assist you with this matter.
Albert R.
I STILL CANNOT REPLY ON MY IPHONE
That is the crux of the delay. No, none of the steps above work. It is a BIOS issue. I asked to downgrade and you told me it was impossible. I would like to upgrade or downgrade. This is why I will likely never buy or recommend an Intel product ever again. There are others which simply work. The IR issues for years, and now the WOL which will not resolve.
