Hi.
I have this issue which has been going on for more than 3 years.
I've also got a replacement pc from Intel.
I’ve posted many questions here and in other places.
Intel® NUC Kit NUC8i3BEH
the thing is my pc will randomly not wake up from sleep.
I’ve implemented many different solutions to no avail.
The malfunction occurs also in linux operating systems.
The bios in my pc is updated to its newest version ( version 89 ).
all of the drivers are also up to date.
I tried many different bios settings including this tutorial. but to no avail.
The issue persists as it has from day one.
So now the bios settings are with 2 V marked on top of my "bios defaults".
Then I checked the USB rubrics.
The other settings were according to the recommendations of the tutorial.
Nothing seems to work.
The malfunction always returns after about 20 times my pc has resumed from sleep mode.
I have no warranty on my pc, and in any case, I believe the malfunction will always return in this model if not more so.
I am very willing to provide any information needed.
https://www.intel.com/content/www/us/en/support/articles/000039550/intel-nuc/intel-nuc-kits.html
“...the following settings:
- Advanced > Devices > Onboard Devices > Auto Turn On TV > Select "From S3/S4/S5 Boot".
TV turns on when Intel® NUC is powered on or resumes from S3/S4/S5 state. - Advanced > Power > Secondary Power Settings (Right Section) > Deep S4/S5 > Select Disabled.
Disable to allow to wake up from other methods besides the power button. - Advanced > Power > Secondary Power Settings (Right Section) > USB S4/S5 Power > Enabled.
Enable the USB Port power in S4/S5 state. - Advanced > Power > Secondary Power Settings (Right Section) > Wake on USB from S5 > Enabled.
Enable Wake on USB from S5 state....”
Which model NUC?
The bios default settings are no good.
The tutorial in the aforementioned link is no good also.
I've also re installed the bios as a bios update with F7 key. the install went ok but the issue remains.
There must be some other setting which should resolve the issue but i don't know what it is.
this far i've tried also
Advanced > Devices > Onboard Devices > Auto Turn On TV > "From S3/S4/S5 Boot"
Advanced > Power > Secondary Power Settings (Right Section) > Deep S4/S5 > -Disabled.
I did some screen snips but the bios returned an error when i tried to save it.
So I took a pic with my phone.
During the past 3 years , it was almost everyday my pc failed to wake up from sleep.
No matter what i did the issue persisted.
also in linux as well as windows.
I tried upgrading the bios versions.
Tried replacing my ram card.
Booted from USB with linux.
tried different settings in the bios.
I also tried hibernation instead of sleep ( S3 ).
tried also the recovery jumper.
I also re-installed the bios in F7 option with was successfully installed.
and this pc is my replacement pc..... Not the original one. but both had the same issue.
I don't know anything.
Maybe it's my fault and I dont Know it.
But I want to find out.
I know it's a heavy threat but I consider buying some other mini pc.
Respectfully- I think it would be more fair if someone in intel would admit there's a serial problem with intel NUC regarding this issue mentioned above.
It's not fair to just keep on giving me futile advices nor keep silent.
Someone should admit this.
Hello R_Kede,
I am sorry to know that you are experiencing this issue and I do appreciate the information provided.
Deivid A.
Thanx.
Hello R_Kede,
In this case, as a test, I would like you to try the graphics version 30.0.101.1660.
- Driver: https://www.intel.com/content/www/us/en/download/19350/intel-graphics-dch-driver-for-intel-nuc.html
- Steps: https://www.intel.com/content/www/us/en/support/articles/000057389.html
Please let me know if the issue persists.
Deivid A.
Hello R_Kede,
Thanks for your reply. I will be waiting for your confirmation if version 1660 worked. If this version did not work, please try version 26.20.100.8141 and let me know if this old version helped.
- Driver (26.20.100.8141): https://www.intel.com/content/www/us/en/download/19344/29530/intel-graphics-windows-dch-drivers.html
Thanks for your comprehension.
Deivid A.
with driver version 30.0.101.1660 the issue re-occurs.
I'll try the other one.
I've installed version 26.20.100.8141.
The issue persists with this driver also.
It's my new ssu report.
I think the issue afore mentioned , resides in a much deeper lever than drivers.
I have been using this pc for 3 years to know that.
I suspect Intel's staff also know it, but will never admit this.
I don't deserve the truth....
In other forums they call it "the sleep of death".
https://www.reddit.com/r/intelnuc/comments/opewnc/intel_nuc_nuc8i7beh_dead_when_going_to_sleep/
I've already said- this is my replacement pc and not the original one.
The issue has occurred also in linux ( manjaro ).
But no matter what, no one in intel will acknowledge it.
There's something wrong with the bios or hardware, and it's serial.
If i could only get some acknowledgment... but no.
Each day i have to deal with it from a new perspective.
Nobody cares if i say for example- the issue persists also in linux. Nobody cares....
Edited - I Deleted my content. It was irrelevant to aforementioned issue.
I tried many different bios settings to no avail.
Hello R_Kede,
Thanks for the confirmation and the extra information. I am sorry to know that the issue persists after trying both driver versions, I will continue with the investigation to confirm if there are any further steps for you.
I will let you know as soon as possible.
Deivid A.
Any help would be appreciated.
I'll give any extra info i'll be asked to provide.
As long as Intel's staff does not acknowledge there's some serial malfunction.... It's a problem....
Can you explain normally what the problem is?
Yes. My NUC pc randomly does not wake up from sleep mode nor hibernation mode.
It's been going on since day one.
You are dealing with agents who are not authorized to say anything about even the possibility of there being a serial issue. This is simply not the path that these kinds of announcements are allowed to take and they likely won't talk about them even after the fact. You are wasting your time asking. They are similarly not authorized to speculate regarding schedules or features. You are wasting your time asking when a driver update will appear and/or what features or bug fixes will be included in a driver update; they simply are not going to speculate.
Sorry, but this is reality. Blame it on the slimeball lawyers (and patent trolls) out there who sue companies at the drop of a hat over the most ridiculous things; these kinds of rules get put in place because of them.
All opinions are my own,
