since installed, I have problems shutting down Windows 10 x64 on my NUC 8i5BEK with all the latest updates and BIOS version installed. The system apparently shuts down, until the screent turns off, but the fans are still running and the blue LED on the power buttons remains active. I have to press the power button 4 seconds to shut down hard - anytime.
In several webpages the "Fast Startup" is named, and that I have to disable it. This makes no effect on my Intel NUC, so I suspect the problem anywere else, maybe within the BIOS settings.
Do you have any idea what I can try in order to shutdown correctly?
Thanks in advance...
First, set your bios to default settings and also please read this answer https://forums.intel.com/s/question/0D70P000006A2GjSAK
Leon
