Intel® NUCs
Assistance in Intel® NUC products
13314 Discussions
NUC 8i7HVK1 Display Issue
TEDoyle
I am having an issue with my NUC 8i7HVK1. I am not able to get any video output. The problem started when I was doing a BIOS update and the update failed. At this point the system was completely unresponsive. There was no disk or display activity on powerup. Prior to this incident there were no system issues. I had also performed a number of prior BIOS updates.
I followed the instructions for performing a BIOS recovery by the security jumper. The procedure seemed to work in that the system appears to be going through the normal boot process (e.g. hard disk activity). However, there is no display activity. I have tried various connections via HDMI and DP. I have changed cables. So far, nothing seems to work to get display activity (either at BOIS loading or startup of Windows).
Any ideas?
Tom
LeonWaksman
Please try to disconnect the Power Adapter and the BIOS battery connector and reconnect it after 15 minutes. After power ON, you will see Checksum error warning - continue to Windows.
Leon
TEDoyle
Leon,
Thanks for taking time to reply. I tried what you suggested. However, there was no change. There is no display activity. However, the system appears to be loading Windows. This is based on the hard drive led activity.
Tom
AndrewG_Intel
Hello @TEDoyle
We are checking this thread and we would like to know if you need further assistance. Please do not hesitate to contact us back if you have additional inquiries and please let us know the BIOS update version that you were running when this issue was triggered.
Andrew G.
TEDoyle
Andrew,
Thanks for taking the time to respond to this matter. I have not been able to get my NUC 8i7HVK1 working. My problems began about 6-8 months ago when I was using the Intel DSA utility to update drives/BIOS. the Intel DSA prompted me to perform an update. At the time there were a few drives and the BIOS that required updating. I am sorry to say that I don't remember the BIOS version information. However, the Intel DSA never finished the BIOS update. It just stopped working. It should also be noted that I had previously used the Intel DSA utility on a number of previous occasions to update drivers and the BIOS with no issues.
Any help that I can get my system back to life will be greatly appreciated.
Tom Doyle
LeonWaksman
Hello Tom.
In your first post you mentioned that you tried to recover your BIOS with the yellow secure jumper removed but you don't remember what was this BIOS version.  Since your NUC display is not appearing, I'm suggesting that you may try to recover BIOS to older version - 0059. Some user, reported problems after updating BIOS with version release after 0059. In case that you want to try this, I'm attaching bios file HN0059.bio. Copy this file to USB stick fully formatted to FAT32, insert this USB stick into rear USB port and power your NUC after removing the yellow security jumper. Wait ~5-6 minutes till recovery finishes. In the end, disconnect the Power Adapter and replace the jumper between pins 1-2.
Leon
TEDoyle
Leon,
I apologize for not being clear about the issue history. When I was referring to not knowing the BIOS version information, that was in reference to when I had my problem with doing the Intel DSA utility update about 6-8 months ago. My first attempt at updating the BIOS with the yellow jumper removed used HN0064.bio with no success.
Yesterday, I used HN0059.bio as you recommended. However, I got the same result. The system appears to be booting correctly (based on HD LED activity) but there is no display information (tried both HDMI and DP).
It looks like my options are running out. I do appreciate you taking time to offer your assistance.
Tom Doyle
LeonWaksman
Hello Tom,
Sorry that I can't help. I understand that you tried also the option for disconnecting the CMOS battery and the Power adapter and reconnecting it after 15 minutes?
As you probably know, NUC is covered by three years of international warranty. Did you check the Warranty Coverage for your NUC?
Leon
AndrewG_Intel
Hello @TEDoyle
We found that you have submitted an internal support request with Intel® about this same issue and Intel® Customer Support is already assisting you. Having said that, in order to avoid duplication of effort we will close this thread now and the support will continue through the internal case.
If you need any additional information, please submit a new question as this thread will no longer be monitored. Thank you for your understanding and happy new year!
Andrew G.
