Community
cancel
Showing results for
Search instead for
Did you mean:
AFern13
NUC D54250WYK no network link
I have Intel NUC D54250WYK. I have installed Redhat and Fedora but I cannot get the network communication establish.
Fedora shows the following for "lspci -vv | grep -i ether" :
shows the chips set as 'I218-V [8086:1559]
In the past I have installed Linux, RHEL on several NUCs. I have always configured BIOS for Legacy mode so that I can kickstart.
In this case since I am having trouble I used "e1000e-3.3.6.tar.gz", I tested installing from a Live CD/USB.
I also downloaded the - driver from - https://downloadcenter.intel.com/download/15817/Intel-Network-Adapter-Driver-for-PCIe-Intel-Gigabit-... Download Intel® Network Adapter Driver for PCIe* Intel® Gigabit Ethernet Network Connections Under Linux*
But nothing is working.
During power up I can see the link Green LED on the interface.
Then when I boot into the OS, I loose the link light.
This gives me an indication the driver is not working.
I appreciate if someone can give me a great sense of direction.
Community Manager
Hi Arthur001,
Thank you joining the Intel® NUC Community. I am sorry to hear you are having issues with this matter.
I have sent you a private message, please check your inbox it.
Amy C.
Community Manager
/thread/119307 Arthur001, hope you were able to check it.
Amy C.
