Community
cancel
Showing results for
Search instead for
Did you mean:
MRENA2
NUC DCCP847DYE + Intel Wireless 7260 N with Bluetooth
Jump to solution
I'm using a NUCNUC DCCP847DYE and I just purshased an Intel Wireless 7260 N with Bluetooth.
I'm running Windows 10 up to date.
I Installed the last driver for the board 19.X and I can see only the bluetooth adapter in Windows.
The bluetooth is working well but I don't see any Wifi device.
Any idea ?
I have try the tap on Pin 20 and 51 but nothing change.
I have the last Bios available.
Thanks for your help.
Accepted Solutions
MRENA2
I finnaly get it works. I install the Wifi Card inside another Computer. In this case, the bord was seen immediately. After installing both drivers, BT and Wifi was working.
I replug the card inside my NUC and the wifi is OK.
Just a little stange.
Regards.
n_scott_pearson
Super User Retired Employee
Did you install both the Bluetooth and Wireless drivers? Did you install the Bluetooth driver first? If not, uninstall the Wireless driver, reboot and then try installing it again.
Hope this helps,
MRENA2
Thanks for the quick reply.
I tried different version of the driver. I'm not sure if I install Bluetooth driver first. But, what I forgot to tell is that I don't see any hardare for the Wifi.
After the Bluetooth driver Installation, bluetooth hardware was detected.
But for the wifi, I can't see any unknown hardware in Device Manager or anything else.
I will try on wednersday to uninstall bluetooth and wifi driver >> restart >>install bluetooth >> restart and install wifi driver. But it seems to be a little strange that i can't see any board in device manager. I didn't check if the board appears in hidden hardware but, it seems a little bit strange.
Best regards.
MRENA2
I just try this morning :
- Uninstall BT and Wifi Driver
- Restart
- Install BT Driver
- Restart (BT OK)
- Install Wifi Driver (Wifi KO)
- Restart Wifi KO
I have no Wifi or unknown devices hidden in devices Manager.
If anybody have an idea. Maybe the wifi card is broken, but it seems that different people have seen some strange behavior with Intel Wifi 7260 with last version of Windows 10.
Regards.
MRENA2
Regards.
