Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
NUC DE3815TYKH won't shutdown with Ubuntu 15.10
Jump to solution
When I press the power button or shutdown from the command line, the device starts shutting down but hangs at the line "Reached target shutdown". I have to hold the power button for 5 seconds to get it to reset. This is with firmware TYBYT10H.86A.0046.2015.1014.1057. Any suggestions? I've tried messing around with kernel acpi options but none of them seemed to help.
Accepted Solutions
Highlighted
I reported this same defect 5 months ago, and after all this time support's first reaction as usual was still to blame the OS. Unbelievable! It is not a driver bug, you will find this defect is not present when using an earlier BIOS. I find disabling USB 3.0 to be a completely unacceptable "workaround".
Highlighted
Hello, laner:
Thank you for contacting the Intel Communities.
As per my research on the error, I was able to find out this is happening in different systems from different brands.
And also it seems like it is a reported bug from the OS.
My recommendation would be to visit the OS' forums to find a possible solution for the bug in the OS.
https://lists.ubuntu.com/archives/foundations-bugs/2015-November/258798.html [Bug 1464917] Re: reboot hangs at 'Reached target Shutdown'
https://bugs.launchpad.net/ubuntu/+source/systemd/+bug/1464917 Bug # 1464917 "reboot hangs at 'Reached target Shutdown'" : Bugs : systemd package : Ubuntu
http://askubuntu.com/questions/620132/laptop-doesnt-shut-down-lubuntu-15-04 shutdown - Laptop doesn't shut down - Lubuntu 15.04 - Ask Ubuntu
If you require any further information or support, feel free to contact us back.
Esteban C
Highlighted
Thanks Esteban.
Highlighted
Interestingly, if I go into the BIOS and change Boot Configuration -> UEFI Boot -> OS Selection from "Linux" to "Windows 8.x/Windows 10" then power down works properly under Linux!
Any idea what that setting actually changes?
Highlighted
Found a solution! Disabling Devices and Peripherals -> USB -> USB Configuration -> XHCI Mode did the trick. I guess there is a bug in the linux xhci driver...
Highlighted
Hello, laner:
Thank you for providing your outcome and workaround for this scenario, it will help other peers having this scenario for sure.
If you require any further or future information/support, feel free to contact us back.
Esteban C
Highlighted
Highlighted
I know what you're saying. Fortunately we're only using the nuc as an interim solution - the AMD-based Fujitsu S720 on my desk is a lot quicker!
