when I turn up my intel DT-22011 NUC I get three very small horizontal windows screens on my 4K monitor.
Hello @rggavitn
We are unable to determine the exact model of the device using "DT-22011" as a reference. In order to provide the proper support, could you please confirm the exact model of the Intel® NUC? Please check the label located at the bottom of the device's chassis and refer to the Product Code and/or Regulatory Model. You may also take a high-quality picture of the device showing the Product code/model and the serial numbers and provide it to us through a private message.
Also, could you please elaborate more regarding the issue that you are experiencing? You may also share some pictures or a short video to show the issue so we can understand better the behavior.
Finally, please run the Intel® System Support Utility (Intel® SSU) in case we need to gather more details about the system:
- Download the Intel® SSU and save the application on your computer
- Open the application, check the "Everything" checkbox, and click "Scan" to see the system and device information. The Intel® SSU defaults to the "Summary View" on the output screen following the scan. Click the menu where it says "Summary" to change to "Detailed View".
- To save your scan, click Next and click Save.
- Once you have saved the file (.txt file), please attach it to your reply.
To upload and attach a file, use the "Drag and drop here or browse files to attach" option below the response textbox.
Andrew G.
Hello rggavitn
Thank you very much for your response and for your confirming the product code (NUC8I7HNK).
We understand that you have solved the problem with the help of a computer store. We are glad to know that the problem is fixed and thank you for taking the time to share this feedback.
Having said that, we will proceed to close this thread now. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Note: We have removed the Serial Number from your reply to protect sensitive information about your Intel® NUC.
Andrew G.
