Intel® NUCs
12101 Discussions
NUC HDMI --> Monitor Display port feasible or not?
RBeck12
I have NUC 8I5BEK; it works fine with my monitor's DVI using hdmi-DVI cable. I wanted to use monitor with NUC hdmi --> Monitor Display port, but see nothing. Can I connect NUC hdmi to DP or is that not supported?
Also I see possibility to use the usb-c port to connect to DP; can I use that with just a single monitor?
LeonWaksman
  1. You can connect HDMI output to DP port on your monitor. The HDMI to DP cable/adapter should be verified that is working and so the monitor. You need also to choose the right monitor input (i.e. DP).
  2. You can also use (and I prefer this solution), USB-c to DP connection. Again use correct cable and choose the DP monitor input.
Leon
RBeck12
So the cable I got my boss to buy is not working :(
I did know about selecting the Display Port input, but that (or auto select) made no difference.
Alberto_R_Intel
RBeck12, Thank you for posting in the Intel® Communities Support.
I just wanted to check if the problem is still present or if by any chance you were able to find the proper cable/adapter for this configuration?.
If the problem remains, please provide the model of the monitor/TV you are using so we can further assist you.
Alberto R.
Under Contract to Intel Corporation
Alberto_R_Intel
RBeck12, Since I have not heard back from you, we are closing the case, but if you have any additional questions, just reply back or post a new question.
Alberto R.
