I'm looking at utilizing the internal 4 pin connector to supply power to the NUC, but I can't figure out from any documentation that I've found where to run the wires. Has anyone done this or have pictures? These will be put in production machines, so the housing and everything will need to be all put back together.
Anything would be very helpful. Thank you.
The connector is fully documented in the Technical Product Specification for the NUC in question. Links for downloading the TPS documents can be found here: Intel NUC Technical Product Specifications.
