Community
cancel
Showing results for
Search instead for
Did you mean:
FApon
NUC Kit selection suggestion for Robotic Application?
Jump to solution
Hello guys,
I am trying to get a quote of a NUC for a Robotic application, I have spent the last 3 hours looking for the perfect fit with no luck, also I have many doubts about if is mandatory to buy RAM memory and Hard Drive (if not which would be the final features). If you can help me I leave here my requirements:
  • Processor of at least 2 cores and 2.0 GHz
  • RAM memory of at least 4GB
  • Memory space or Hard drive of 32 GB or more
  • Compatible with Ubuntu 16.04 TLS
  • 2 Ethernet ports, if its not possible include the accessory compatible
  • And finally it would be great to have an enclosure of IP 65
I would say that I have for this purpose the budget of around 450 USD
Thank you very much for your help
Community Manager
Hello, fhfonsecaa.
I understand you would like to get a suggestion of a NUC in order to run a Robotic Application. I will be more than glad to assist you further.
By checking the requirements you are looking for listed above, allow me to share with you some information:
First, in order to check the specifications of our Intel® NUCs you can access this link: https://ark.intel.com/# @PanelLabel70407 https://ark.intel.com/# @PanelLabel70407
Then, please bear in mind that our NUCs do not include any RAM or SSD and, they will have just one ethernet port. There are some exceptions where the NUC has embedded storage.
Furthermore, here is a link where you can check the Operating Systems compatible with our Intel® NUCs: https://www.intel.com/content/www/us/en/support/articles/000005628/mini-pcs.html https://www.intel.com/content/www/us/en/support/articles/000005628/mini-pcs.html
Additionally, you can check the tested peripheral for some NUCs using this link: https://www.intel.com/content/www/us/en/support/articles/000005676/mini-pcs.html https://www.intel.com/content/www/us/en/support/articles/000005676/mini-pcs.html and https://www.intel.com/content/www/us/en/support/articles/000020804.html https://www.intel.com/content/www/us/en/support/articles/000020804.html
Now, with the specifications you are looking for, I can suggest the https://ark.intel.com/products/95066/Intel-NUC-Kit-NUC7i3BNH NUC Kit 7i3BNH, https://ark.intel.com/products/95067/Intel-NUC-Kit-NUC7i5BNH NUC Kit 7i5BNH or https://ark.intel.com/products/84860/Intel-NUC-Kit-NUC5i3MYHE?q=5i3MYHE NUC Kit 5i3MYHE. You can also check the https://ark.intel.com/products/series/129709/Intel-NUC-Kit-with-Intel-Pentium-Processors Intel® NUC kit with Intel® Pentium® Processor and https://ark.intel.com/products/series/129710/Intel-NUC-Kit-with-Intel-Celeron-Processors Celeron®.
I hope this answers all your questions.
Antony S.
Community Manager
Hello, fhfonsecaa.
Antony S.
