Intel® NUCs
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
NUC LED Ring
CShel
I just got a NUC8i5BEH and I was wondering if this model has the LED ring on the front panel. I see the setting in the bios for the ring, but I cannot get it to work. I have tried both available bios updates, but no luck.
Community Manager
Hello HardRockinRed,
Thank you for posting.
What is your setting in the BIOS for the LED Ring?
What is your BIOS version?
Amy C
Under Contract to Intel Corporation
CShel
I have tried BIOS 0048 and 0041. I have set the ring for Power State Indicator, HDD Activity LED and SW Control. When I set it to SW Control, I downloaded the Intel Nuc LED Controller software, but it does not show any LED's to control.
Community Manager
Thank you for the information.
Your model does not have a LED Ring, the settings you configured will be reflected in the power button. You can confirm that there is no LED Ring by viewing the Chassis Front Panel Features on page 75 from https://www.intel.com/content/dam/support/us/en/documents/mini-pcs/nuc-kits/NUC8i3BE_NUC8i5BE_NUC8i7... https://www.intel.com/content/dam/support/us/en/documents/mini-pcs/nuc-kits/NUC8i3BE_NUC8i5BE_NUC8i7...
If you are referring to the following https://downloadcenter.intel.com/download/27641/NUCs-LED-Manager-for-Intel-NUC Download LED Manager for Intel® NUC, this will not work for your Intel® NUC model. The download is for the Intel® NUC Kit NUC8i7HNK and Intel® NUC Kit NUC8i7HVK only.
Amy C
darkf3d3
Hello idata, I have a NUC8i5BEH too where I'm trying to disable led, but I can't find a way to disable both them from bios.
I followed the step you wrote here but then only one of the 2 led it's turned off:
https://forums.intel.com/s/question/0D50P0000490BlYSAU/how-disable-power-button-led
I saw that from the bios you can set the led to be software controlled, but Intel LED manager it's compatible only with NUC8i7HNK and NUC8i7HVK. So which software we should use?
