Intel® NUCs
Assistance in Intel® NUC products
All support for Intel® NUC 7 - 13 systems is transitioning to ASUS. Read more.
13493 Discussions
NUC NUC7JY: hdmi primary output changing after each restart
CompuMat
I am using Linux (Ubuntu) on the Intel NUC (BOXNUC7CJYHN2). This NUC provides 2 hdmi ports. After each restart I have to plug the screen to the other hdmi-port, to see the Linux screen. BIOS screen is visible on both ports all the time. Means:
Starting the system, after having Linux up and I migh not see the screen, I have to move screen-hdmi-plug from one hdmi port and plug it into the other port. When then restarting, after Linux is up and running again, the screen is black and I have to plug screen to the other hdmi-port.
The start screen always appears on both ports.
How can I fix the output to one port? Or am I able to disable one hdmi-port in BIOS? How?
David_G_Intel
Hello CompuMat
Thank you for posting on the Intel️® communities. Please share more information with us:
  • Please explain the connections used (graphics, cables, monitors)
  • Which BIOS version do you have?
  • Are your drivers up to date?
  • Provide the Intel® System Support Utility (Intel® SSU) results
David G
David_G_Intel
David G.
David_G_Intel
David G.
