just bought NUC8i7HVK few days, connect with 6 monitors/ less, problem is when connect any screen via mini hdmi port at the back, when leave the monitor turnoff via control panel win10 pro, the system is freeze, need to hold & push power button to shutdown and restart.
while using the system, there is no any problem / symptom, if leave the desk and monitors shut down it shall FREEZE!!!
so I have to use the front hdmi instead.
please see my photo and specification here
https://drive.google.com/drive/folders/1rxTz69v123L-sMvQowL7z0A_wk5BcQ9C
I have to stop my plan for adding 2 more monitors, because the mini HDMI cause problem, please help!!!
the first problem is, I try to install the the Intel® graphics driver version 25.20.100.6519 (both download and web version) is not supported by this process type, please advise.
This had already pass, because after update windows 10, It could possible to install now.
the 2nd problem is when start to install GFX_Radeon_WIN10_18.12.2
is not success, and the error report as capture
after update windows 10, seem all the driver working well, incl. this GFX_Radeon_WIN10_18.12.2
all the 6 monitors are up.
I am currently update windows 10, after updated will try to install the driver you suggest again.
I have attached the sysytem details both expand detail and full scroll capture.
FYI, I have reinstall windows 10 and would like to inform you my update hardware configuration and photo as attach, totally 6 monitors and use all the portsports.
I just received an email from Intel support as attach, please check.|
I would follow both of your advise asap.
also update TI_USB_PD_WIN10_64_1.0.4.11 and it look good too.
I have do all the things you list, and It work well, all the driver are up to date,
except only Thunderbolt TBT_WIN10_64_DCH_1.41.645.0
didn't install,
I try to find in the device to update, but cannot find, can you advise me again please?
