Intel® NUCs
Support for Intel® NUC products
Do you have improvements you would like us to make on this community site? If so, we would love to hear your feedback! Click here for an 8 question survey. Thanks!
11321 Discussions
NUC USB 3.0 Driver For Windows 7 Cannot 'See" Keyboard
BGow0
I have been unable to successfully boot my NUC8I3BEH into Windows 7 Ultimate from a boot USB stick. Have read quite a few threads and web pages on how to do this, and I have followed the Intel guide “Install Windows 7 on USB 3.0 Computers - August 2018”. I used the manual command line version of DISM via a Windows Powershell (Admin) method – drivers were successfully added and the boot.wim and install.wim copied back to the Windows 7 boot USB stick (used index:4 for the install.wim file and index:1 and index:2 for the boot.wim file). Unfortunately the NUC cannot get past the first Windows 7 install screen because the keyboard and mouse cannot be “seen”. I used the latest version of USB 3.0 drivers from the Intel downloads web which were “Intel(R)_USB_3.0_eXtensible_Host_Controller_Driver_5.0.4.43_v2” and the keyboard is via USB cable. My NUC has the latest version of BIOS which is 86A and I am using the Legacy boot from USB stick.
I have easily installed Windows 10 Pro, but I don’t have a product key for that version – that is why I need to install Windows 7 because I have a key for Win 7, then activate it, then I can overlay Windows 10 on top of that. I realise Windows 7 is not supported on my NUC, but it’s only a means to get to the end.
My final option is to buy an adapter cable to plug into the USB 2.0 4-pin header on the motherboard, so it can see a keyboard, but the software solution should work, and I don’t like to give up easily. So has anyone else had a similar problem who can please offer some advice.
AlHill
Only Windows 10 is supported on your nuc. Specifically, only WIndows 10 is supported on 7th gen and later processors.
And, Windows 7 only has a couple of months support left from Microsoft, so get a Windows 10 key, and be supported.
Doc
DKoma3
Hello mate.
The same here. I tried to install 32bit Win10.
Not possible because of uefi 64b only.
Win 7 64b should work though.
DKoma3
Ah, i have tried usb 2.0 - same, it just turn off port.
BGow0
Hi There,
I ended up buying a cable - USB2.0 to 4pin-header connector to try and install Win 7 that way - but this also failed for me. I tried disabling the other USB3.0 ports via the BIOS, but no matter what I did, I still could not communicate to the NUC via USB 2.0.
So I gave up.
AlHill
Let us try again - Only Windows 10 is supported on your nuc. Specifically, only WIndows 10 is supported on 7th gen and later processors.
Doc
