I use my Sanyo PLV-Z2000 projector for big screen streaming of Netflix, HBO, TV-signal etc. I have recently exchanged my computer to a NUC7I5BNK. Last night I wanted to show a movie for the family and got this on the screen:
It worked fine with the old computer. Is there anything I can do on the NUC to make it work?
Anders
Hello kaja69,
Thank you for contacting Intel® technical support. I will be more than happy to help you.
I understand that you are having issues with an Intel® NUC Kit NUC7i5BNK and a Sanyo* projector regarding the support with HDCP.
This NUC Kit supports HDCP 2.2, and it is very likely that the projector is currently using a different version. Please check the settings of the Sanyo* project to find any information about HDCP. You can also try updating the firmware of the projector, which very possibly will provide it with more support.
Xavier A.
Thanks but I found that the problem was my AVR that blocked streaming when I was using the Edge browser. When using Chrome it works just fine. So the NUC nor the projector is the actual issue.
Hello kaja69,
I am very glad to know that you found both the cause of the issue and the solution. Thank you for letting us know.
Xavier A.
