Intel® NUCs
Support for Intel® NUC products
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11880 Discussions
NUC configuration w/Optane storage
Petri
I am considering to try out a Hades Canyon i7 Vega NUC kit, and would like get some opinions on the following configuration:
  • 16 GB of DDR4 2400 MHz SDRAM
  • Primary storage: Intel Optane P900 280 GB
  • Secondary storage: External 4TB USB 3.1 drive
The external storage is really for VM images, large files or database content that is not latency/performance sensitive, and as a backup device of the primary drive.
The use cases range from running a few virtual machines for software demonstrations (that can all fit on the primary drive) to occasional gaming. I also want to try out the VR capabilities in due time.
Is this a good high-performance configuration, or should I consider an all M2.NVMe SSD drive option instead?
Thanks, Petri
LeonWaksman
The Intel Optane P900 280 GB has U.2 15mm or HHHL (CEM3.0) form factor. The NUC8i7HVK has two M.2 slots. I don't see how you can use this Intel drive. In my opinion, you should consider M.2 NVMe SSD as primary system drive.
Leon
