Buen dia, un problema con una nuc de3815tyke que cuando la enciendo no da video y el led del disco duro no enciende en ningun momento, ya se probo con otras memorias ram y otro Disco duro pero la falla continua
Does it actually turn on? Is the power LED coming on in the power switch when you press the power button? If you open the case, can you see the green LED lighting to indicate the board is receiving standby power from the power supply?
Hello @MiguelMedina
We hope that the assistance provided by the community has been helpful.
We would like to inform you that due to the Intel® NUC Kit DE3815TYKHE has been discontinued, Intel Customer Service no longer supports inquiries for it, but perhaps fellow community members have the knowledge to jump in and help. You may also find the Discontinued Products website helpful to address your request.
Note: You might need to search for the proper Product Category and click on its "Show more" link if the product is not visible in the top rows.
Andrew G.
