Community
cancel
Showing results for
Search instead for
Did you mean:
TKmet
NUC dead (power button no react)
Hi all,
I have a NUC 7i5BNK and an issue "dead NUC" appeared from day to day.
I have tried all suggestions below but nothing helped:
1. BIOS Recovery by the Power Button Menu
-> after power button pressed nothing happened
2. BIOS Recovery by the Security Jumper
-> no reaction on power button press
3. Disconnect the power cord from the AC power source for 30 min
-> after assambling everithng togerther pressed power button, but no response
4. Pressed power button for 3-more seconds
-> Nothing helped
5. Removed RAM and HD
-> after pressing power button nothing happens
6. After connection to AC power cord
-> internal led is off
Is there some other suggestion?
Thx.
Tags (1)
JRayn
Replace the power button?
LeonWaksman
Check if your Power Supply is working (measure voltage).
Leon
Community Manager
Hello, Tibiman.
I would like to know if you could follow the steps provided by JNRW and lw1948?
Antony S.
