Intel® NUCs
Assistance in Intel® NUC products
13292 Discussions
NUC i3 10th Gen — 5120x1440 output in Linux?
benfrain
I wondered if someone could confirm if a 10th Gen NUC i3 should be able to output 5120x1440 in Linux (using Fedora if that matters)?
Considering investing in an Ultrawide monitor and want to be sure NUC can output that resolution in Linux?
Maria_R_Intel
Hello benfrain,
Thank you for posting on the Intel* Community Forums.
The supported and validated Operating System for the Intel* NUCs with 10 gen processors is Windows* 10. According to our specifications, the NUC can reach a maximum resolution of 4096x 2304 (4K) @ 60Hz with the drivers of the supported OS. You can check this on the Technical Product Specifications.
I need to inform you that Intel has not tested and validated this Intel NUC model with any Linux distribution; however, we have plenty of positive reports from customers that are using the unit successfully on many different Linux distros.
You can check the Intel Compatibility Tool for the NUC model in case you are interested.
Also, most Linux-based* distributions include Intel® Graphics Drivers. These drivers are provided and maintained by the Linux* distribution vendors. Contact your operating system vendor (OSV) in case you want to use Linux* and use their distribution for driver access and support.
Maria R.
Maria_R_Intel
Hello benfrain,
We have not heard back from you, so we will close this thread. If you need any additional information, please submit a new question as this thread will no longer being monitored.
Maria R.
