Der Rechner verliert über W-LAN sporadisch die Verbindung zum Internet. Manchmal alle 10 Minuten, manchmal hält die Verbindung über Stunden.
- die Treiber sind aktuell
- Signalstärke ist maximal
- alle anderen Geräte an dem Router funktionieren über W-LAN einwandfrei
- Bandbreite mehr als ausreichend
- habe auch auf anderen Router gewechselt, Problem bleibt.
Das Trennen der Verbindung zum Router und das sofortige wieder einloggen stellt die Internetverbindung sofort wieder her.
Download, run, and ATTACH (using the paperclip under the toolbar) the results of this utility:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Doc
To specify the error. The connection to the router remains established but the "globe symbol" is then displayed in the status bar and the error message is "no internet". But all other devices connected to the router via W-Lan work fine.
herbb, Thank you for posting in the Intel® Communities Support.
I just wanted to check if the problem of losing Internet connection when using the Intel® NUC Kit NUC8i7BEH still persists and if you need further assistance on this matter?
Albert R.
A Contingent Worker at Intel
Dear Albert,
thx for your answer. Yes, the issue still persists and I need further support.
Best regards
herbb
Hello, herbb, Thank you very much for your response, we will be more than glad to further assist you with this scenario.
In order for us to provide the most accurate assistance, we just wanted to confirm a few details about your system:
What is the model of the Router?
Is this a new Intel® NUC?
Was it working fine before?
Did you make any recent hardware/software changes?
When did the issue start?
Did you check with your Internet service provider to make sure the Internet is working properly?
Does the problem happen at home or work environment?
Albert R.
Dear Albert,
following the answers to your questions:
Compal ch6640e
I´ve tried it in addition with the neighbor´s router. Other Router model, the NUC issue remains.
Yes, it’s a new one, a couple of months old.
No, the error exists since I have the NUC. Sometimes the NUC works fine and the loss of the internet connection happens only twice a day. Sometimes it happens every ten minutes. All other devices connected to the same Router over WLan are working fine.
No. I made the regular Windows updates and the updates over the Intel driver and support assistance.
Since I bought the NUC.
As mentioned the connection with other devises connected to the same WLan Router are working fine. I did the test and streamed a TV program over the NUC and in parallel over my I-Pad. The NUC lost the connection several times and the I Pad was working fine.
At home.
Best regards and Thank you for your help.
herbb
Hi herbb, You are very welcome, thank you very much for providing that information.
In the link below you will find the Advanced Intel® Wireless Adapter Settings, there are some troubleshooting steps that we can try. Since the Intel® Intel® NUC Kit NUC8i7BEH works with the Intel® Wireless-AC 9560 card:
https://www.intel.com/content/www/us/en/support/articles/000005585/network-and-i-o/wireless-networking.html
- Set the Wireless Mode to VHT mode or 802.11ac only.
- Test bot bands separartely on 2.4Ghz and also on 5Ghz
- Setup Advance\Channel Width for 2.4Ghz and 5.0Ghz on 20Mhz Mode (forced from Auto to 20Mhz)
- Disable the Fast BSS Transition Roaming
Please let us know the rsults of trying the steps above.
Albert R.
Hello herbb, I just wanted to check if the information posted previously was useful for you and if you need further assistance on this matter?
Albert R.
Dear Albert,
thx for asking.
I did two things:
- I changed the „Setup Advance\Channel Width to 2.4Ghz“ and
- I installed the last graphics driver update
Then it worked two days without any problem
Then changed the „Setup Advance\Channel Width“ back to the standard setting.
The NUC work since then without any interruption.
Is it possible that the graphics driver update has fixed the error?
Best regards
herbb
herbb, You are very welcome, thank you very much for sharing those results.
Perfect, excellent, it is great to hear that the Intel® NUC Kit NUC8i7BEH is now working properly and there are no more problems with the Internet connection.
Regarding your question, yes, it is possible, not very common that a Wireless problem gets fixed by installing the latest Intel® Graphics driver, but it could happen. Keep in mind also that Windows* is constantly installing updates so probably it has to do with that as well.
Any other inquiries, do not hesitate to contact us again.
Albert R.
