Intel® NUCs
Assistance in Intel® NUC products
13309 Discussions
NUC i815BEH HDMI firmware update not working.....
jsmiddleton4
Trying to run the HDMI firmware update tool.  Says can't connect to system?
See attached.
What am I doing wrong or is this the way its telling me the update isn't necessary?
Same system can't message when just trying to check firmware.
LeonWaksman
1. Is your monitor ON and connected to the HDMI port?
2. When you launching BobcatAuxISPTool.exe tool, did you select Run as administrator?
Leon
jsmiddleton4
Yes to both.
LucF
Hi, I believe it is necessary to install the last version of Intel Graphics DCH Drivers (not legacy), but I ask the experts for confirmation.
jsmiddleton4
Anything is of course possible.  Given the update was released prior to those DCH drivers it seems unlikely.
My NUC is one of those with only one HDMI port.  Maybe the update gets confused when that's the case?  Who knows......
LucF
I meant the Intel Graphics Drivers must be DCH.
If legacy driver is installed, the update does not work (I believe).
I had the same problem with my NUC (only one HDMI port) and installing DCH driver I solved it.
Bye
jsmiddleton4
Doesn't say DCH but it is the driver from 9/2021.
The Download page refers to it as the DCH driver.
I installed it before trying the HDMI firmware update.
DeividA_Intel
Hello jsmiddleton4,
In order to better assist you, please try the following:
1. Run the Intel® System Support Utility (Intel® SSU) to gather more details about the system.
· Download the Intel® SSU and save the application on your computer: https://www.intel.com/content/www/us/en/download/18377/25293/intel-system-support-utility-for-windows.html
· Open the application, check the "Everything" checkbox, and click "Scan" to see the system and device information. The Intel® SSU defaults to the "Summary View" on the output screen following the scan. Click the menu where it says "Summary" to change to "Detailed View".
· To save your scan, click Next and click Save.
2. Do you have an issue with HDMI> If so, can you provide more details?
3. Perform a clean install of the Intel driver:
- Driver: https://www.intel.com/content/www/us/en/download/19344/intel-graphics-windows-10-windows-11-dch-drivers.html
- Steps: https://www.intel.com/content/www/us/en/support/articles/000057389/graphics.html
Deivid A.
jsmiddleton4
Thanks David but I figured it out on my own.  In the BIOS the video has to be set to AUTO.  Since I'm only using HDMI I had set it as the main and only output.  Once set to AUTO, HDMI firmware ran as expected.
DeividA_Intel
Hello jsmiddleton4,
I am glad to hear that you were able to solve the issue by changing some settings at the BIOS. Do not hesitate to let us know if you assistance with our products.
Deivid A.
