Intel® NUCs
Support for Intel® NUC products
12725 Discussions
NUC locking up overnight when turned off - NUC11PAKi5
leon49
Turn the system off at night using Windows shutdown
In the morning the blue power button is lit but the NUC will not start/respond to pushing the button. Holding the button down does not shut down the system. It does not respond to any device configured to wake it up.
The only way to start the system is to remove the power cable
Changed all the setting so the system and screen do not sleep when powered but did not make any difference
Appreciate your advice
AlHill
There are many NUCs.  Which one?
leon49
NUC11PAKi5
i5 2.4Ghz
Windows 10 x64
Jean_Intel
Hello leon49,
Thank you for your response.
If I may interrupt here, I want to confirm some information to have more insight into your issue.
When did the issue start?
Is there any error message when you turn your system on?
Have you experienced any Overheating issues?
You mentioned that you tried all the settings, so the system and screen do not sleep. Is there any issue when the system enters sleep mode?
Create a report using the Intel System Support Utility (Intel SSU)
• Download the Intel SSU (https://www.intel.com/content/www/us/en/download/18377/25293/intel-system-support-utility-for-window...)
• Open the application and click on "Scan" to see the system and device information. By default, Intel SSU will take you to the "Summary View."
• To save your scan: click on "Next"; then "Save."
Jean O.
leon49
Thank you. Responses to questions below.
Issue started about 6 weeks ago
No error messages - boots OK
None that I am aware of
It will intermittently experience the same type of lock up when in sleep mode
Report attached
Jean_Intel
Hello leon49,
Our apologies for the inconvenience. We are working on the solution for your issue. However, if you want, you can try running the drivers 30.0.101.1069 or 27.20.100.9466. If you would like to try these drivers, try a clean installation of the drivers.
Driver 30.0.101.1069 (https://www.intel.com/content/www/us/en/download/19344/685037/intel-graphics-windows-dch-drivers.htm...)
Driver 27.20.100.9466 (https://www.intel.com/content/www/us/en/download/19344/30381/intel-graphics-windows-dch-drivers.html)
Clean installation (https://www.intel.com/content/www/us/en/support/articles/000057389/graphics.html)
Jean O.
Ronny_G_Intel
Community Manager
Hi everyone,
This issue is addressed by GFX driver version 31.0.101.3222, please refer to the following URL:
https://www.intel.com/content/www/us/en/download/739618/intel-graphics-dch-driver-for-windows-10-and...
Ronny G
Jean_Intel
Hello leon49,
We hope you are doing fine.
Best regards.
Jean O.
