Intel® NUCs
Assistance in Intel® NUC products
13318 Discussions
NUC nuc8i7hvk SKULL LED cable
EdE
Greetings.
I recently purchased a nuc8i7hvk (used) and noticed the Skull wasn't lighting up.  Upon opening the case, I found the cable going from the motherboard to the skull LED board was missing.  I chatted with Intel support and they told me to try one of their partners for a replacement cable. I've looked at a couple of recommended NUC reseller sites and haven't found it.
Any sources on where I can get a replacement cable?  (see attachment of one I pulled from a second NUC)
Cheers!
--Ed
Esteban_D_Intel
Hello EdE,
We understand that you had a previous case where you received support about this matter.
I would strongly recommend checking with the authorized partners for the part availability. You can try contacting them directly for a faster resolution.
In case you are interested please check Where you Buy Spare Accessories for Intel® NUC Products
That being said, as the recommendation was provided in the internal case we will proceed with the close of this inquiry.
If you need any additional information, please submit a new question as this thread will no longer being monitored
I really hope that you can find the part with the provider.
Esteban D.
Intel Technical Support Technician
